0-60 time?
CodyTY23
Got Boost?
how do i improve it? i just put on a RPM stage one.I also have cat back exhaust and a K&N barrel filter everything else is stock
epix
Typhoon
Re: 0-60 time?
suspension helps out, if you are looking to better your 0-60 times also start saving for a new transmission!
Re: 0-60 time?
If you want to work on your 0-60 time (either 60' or 60mph) You need make sure your truck running upto par via scan tool, & you need to work on your launch. You will need track time or atleast a G-tech to measure this and record progress. If you have a mostly stock truck and are getting low 1.7's 60' your doing pretty good for a luanch. One thing that help with launch is coilover front springs with their limited suspension travel. Its force the truck to launch flatter and with more front wheel traction. If your doing a lot of boost launches, get a tranny cooler, replace the front propshaft and motor mounts (or get an engine tie down)
gjp
another post whore
Re: 0-60 time?
datamaster and tune. If you are pulling out a lot of timming it will slow you down. with your mods I dont think suspension will help to much. My truck pulled fine with the stage 1 and good sticky tires. I got a qouck chirp and It was off.
gjp
another post whore
Re: 0-60 time?
Stage one is a larger turbo from RPM. Its as close to a bolt on turbo as you can get. It adds about 40hp over stock turbo. Has a better wastegate and looks better.
sy2207
Re: 0-60 time?
I don't know if it is just me but I just cringe when I hear someone saying the have a 'stage x'
Luke
Fish sticks SUCK !!!
Re: 0-60 time?
that is how RPM defines there replacement turbos, but yea I know what you mean, if its anything other than a RPM "stage X" turbo its lame.
