Osmosis
I found a few links such as the one on Detroit turbo's web site regarding the install of the plx wide band onto the stock ECM. IT is a bit confusing and unclear to me where to put the resistors.
I know you need two resistors to enable the ECM to talk to tuner pro.
So, which wires are hooked to the resistors? the PLX black and grey, are the connected to say, black to one side of the resistor and the Gray to the other side of the resistor, then the tails of each black and gray to the ECM? And then what about the purple wire, which I think goes to the O2 sensor. I think that has a resistor connected to it, I'm just not quite sure if anything goes on the opposing side of the resisotr to the purple wire.
On the link and the instructions on the video, it does not clearly say if you need to connect both sides of the resistor or just one wire to one side of each resistor.
I konw the plx black and grey wires are to the ECM. This link is one where I was found some info. There's also a video on Tuney Fish that has a video, however, it does leave out some critial information regarding the purple wire where each side of the resistor goes to.
http://www.detroitturbo.com/wiki/do...evices_sensor_module_wires_to_the_factory_ecm
Thank you guys for the help!!!
Oz:tup:
Oz:tup:
