Syclone2163
I just recently bought syclone 2163 with 74,000 miles on it completely stock (as far as I can tell). The problem is that there are small holes in the exhaust running up and down the pipes from the cat to the bumper. The holes look to be caused by rust. However the pipe from the turbo to the cat is fine. The exhaust looks stock except the mufflers were removed and replaced with straight pipes. I was going to have my local muffler shop just put in new pipes from the cat back. However my question was would it be beneficial to completely remove my cat and just run straight pipes from the turbo back or does the turbo need some kind of backpressure and would it create boost problems. And also should I stick with 2 1/2 inch pipes or jump up to 3 inch all the way back, or at least from the cat back if I go that route.
