WHAT KIND OF INJECTORS
joe
what kind of injectors are these. What would be comparable that i could purchase. Trying to get truck running and I may have an injector issue.
joe
I am having trouble getting truck back to its youthful days. Been sitting for many years. It falls on its face under low boost. It feels similar to a car with a stopped up catalytic converter. I know I’m close to figuring it out. My next step is fuel pump, injectors, and 3 bar map sensor. I think fuel regulator is ok
Goodgollyjosh
I feel your pain brother, went through the same thing when i got mine. So many driveability issues in the beginning. Ended up finding a twisted rubber fuel line at fuel tank on feed side from when previous owner had replaced pump. Good luck with your ride.
joe
Replaced fuel pump and it made a big difference. Still hesitates under boost but now it takes more boost for it to hesitate. Is there a combo I could by for example , 60lb injectors, chip , o2 sensor and air fuel gauge. I have a new 60 series turbo. I just bought those 50lb injectors because that is what’s in it, but considering going bigger.
Goodgollyjosh
I imagine a lot of guys on here, who know sytys way better than me will recommend going over everything with a fine tooth comb...state of tune both hard parts and ecm prom set up, checking vacuum lines, verifying balancer hasn't slipped, verifying ignition timing, fuel pressure, and data logging it if it still has problems.
I've had hesitations on my Sy from fuel pressure being too high at idle, low injector voltage from ecm, plug wires that were grounding out, dirty ground wire connections, down pipe hitting frame and tripping knock sensor...you name it.
proptop
Turbo Tweak on the injectors and chip. Also like Josh stated make sure to do a detailed once over on everything.
Bob
joe
I was hoping to purchase a turbo tweak chip, maybe 60 lb injectors to match 60 series turbo. I just need some direction. Any suggestions on a o2 sensor and great gauge combo ? I think if I did these things it will be running well. Any help would be much appreciated.
