water in the intake port...
Syclone#2960
What ever it takes!!
I was driving around when I noticed the truck sounded like it was missing a cylinder. I looked down to the temp gauge & it was close to the red mark. I turned the truck off and coasted it up my driveway. It ran low on coolant & over heated.
I found the number 1 plug was soaked in water & not firing while running. I figured the intake gasket was leaking (vortecs). I removed it & found a pud of water sitting in the #1 intake port. I soaked it up with a shop towel to dry & decided to hit it with the 5hp shop vac to make sure I got all the water. The water returned inside the intake port while I was vacuuming the port. Did I blow a cometic head gasket? cracked the head? or cylinder wall?:tdown:
Ty 1885
Re: water in the intake port...
If the head is cracked, the best thing to do is to buy new heads and leave the smaller valves in them.
Syclone#2960
shiiit bruce you can't catch a break on these things can ya. The tyhoon right?
yeah it was the typhoon...just installed the wideband from sy to check things out that same day. It's almost a full time job owning these trucks. So much for SAR.
0966Sy
Code what?
I bet the intake is leaking at the crossover. call me Bruce i lost your number when my sim card crashed.
Mikel2000
is this known to happen a lot, i have my heads in the shop and im thinking of enlarging the valves to 2.02 and 1.60's, hearing this makes me want to reconsider...
