The Devils Own Chariot
I have always been getting weird lean spots that come and go around 3% TPS and 30% TPS. Even at idle AFR always seems to be changing. Even after you change the F29x table its good for a bit and then AFR changes again. This condition never happens under WOT.
I can get the truck to idle well if its super rich. like 12.5 to 13.5
I have played with timing,IAC, and RPM using code59
I have some gut feelings:
There is an underdrive pulley on the truck but my battery voltage never drops bellow 13V. Could I have an amperage issue with the underdrive pulley and not a voltage issue?
I test fuel pressure at idle and its solid at 42psi. never fluctuates.Turning the truck off and the fuel pump off I get 0 pressure drop after 30min. I left the fuel pressure gauge on the fuel rail over night and around 8 hours later the pressure is 0.
What is normal here and what is not?
Im also wondering if my 60# injectors are bad.
What can we make of this?
