Turbotweak Chip
IGottaSy
Oh, okay. Would you post the timing/boost the chip is programmed to? My truck is all stock except for a turbo upgrade.
blownoutlaw
Timing 19 degrees at WOT
The timing will vary with rpm
Same as boost but chip will be good to 20psi
I have the order # for chip so if you wanted Turbotweak to change anything for you they can no problem.
