Slyclone
Well-known member
Is it possible to replace or re-do the trans dipstick tube on truck with out doing much? Like disassembly...? With out getting too involved. I tried a few approaches trying to seat it and I had no luck. Right now it's not seated fully.
Have had issues with the tube seating in the actual trans port. Lots of leaking. Very ugly under neath not pretty. Actually dug out my syclone dip stick tube to look at it ( becausd everything is in boxes) and the typhoon one looks cut. Like the bracket to hold it down or in place rather was cut/bent or snapped off for ease of install. Figures right. So far almost everything I have figured out with the truck has been a whole lot of work afterwards.
Every time I mess around with the tube fluid guzzles out ( is that normal?? ) and I'm stuck with cleaning the mess up. I already dumped a few QTS of trans fluid in the past few months. I'm not a trans expert. Like I said every time I end up adjusting the tube it comes loose and I have fluid all over.
Tonite the "roar" is back.. Truck is not moving too well past 4000 rpm and really screaming 3000-35000. I don't know if its a converter again... Lock up? Or my transfer case I put in is going?
Wondering if I am low on fluid or, something went in the transmission. Its just another one of them all the sudden things that just started happening again. I really need to get the tube seated/fixed. Is there a easy button for this one?
