so like a set of weld drag lites? do you know what i would need for the correct offsets?.. and what tires would you recommend that i go with.. drag radials all the way around? are they going to make that much of a difference over a street tire?
This is what I had:
http://www.syty.net/forums/showthread.php?t=68267&highlight=weld
I ran Hoosiers, but if I had it to do again, I'd run the 275 M/T ET Radials like Jamie has.
I could launch with 15 psi with these... I could launch with 4 psi on the stockers.
Shaved 80# of rotating mass vs. the stock wheels + tires, and 17" rims/tires are probably at least 10# heavier than the stockers, if not more.
