Syclone #1721
I LOVE 4UM SUPERSTARS
I have a Borg Warner T56 6 speed setup from a 97 Trans Am. Car had 70k on it. You get trans, shifter, flywheel, pressure plate, throwout bearing, clutch in like new condition, bellhousing, fork and slave cylinder assembly. Clutch appears to have been replaced. Also have the crossmember from the car as well. This is supposedly a stronger unit than the LS1 trans. If you have a 1 pc. rear main SBC(87-up) or 90 degree Chev V6, this will bolt right up to it. You will only need to purchase an LT1 pilot bearing. For pre-86 engines, you will need to purchase a conversion flywheel (Mcleod or Centerforce) and pilot bearing. This is a nice setup. Shifted fine. I bought this to use in my 69 Camaro with an LT1 but have changed my mind and want to use an LS1. It takes too much to convert it so I am selling it purchase an LS1 T56. I will also trade this setup for an LS1 setup if someone is interested...$1700.00 takes it.
