Vaders Sy said:
ivanko barbell said:
What info you looking for?
Adam
What you mentioned before with the mod list and times was what I was looking for. Adam, what exactly do you mean by better intercooling? (Jabsco pump etc?)
Ok here it is.
PTE TE-44 Wet center
PTE 3" Downpipe w/ dump tube open
Mitsubishi 1st Gen Eclipse BOV crushed to hold 24 psi
Ultimate version 6 set to T-1 22 psi.
Boost Command set to ~21 psi. (I set a bit under the overboost limit)
Stock upper IC - Heat Shield Wrapped
Lower IC Exchanger - Tony Dequick
ATR Aux intercooler kit
Jabsco Pump
ATR Cold Air Kit
Air Flow Systems Cobra Head Elbow
Modified Bob Galla Turbo to IC pipe
Custom K&N Cone Filter
Aquamist Water Injection using two 6mm jets and flow meter.
Dual Spal Fans running during entire pass
160 degree thermostat
Redline Oil
Redline Water Wetter
Brian Hartman Stage VII tranny w/ TCS 2800 stall billet converter (tighter version)
Redline Ford Type Racing Tranny Fluid
Lube Guard
Dual Tru Cool run in tranny coolers plumbed in series
TCI SFI Flexplate
ARP Flexplate Bolts
TCI Aluminum Tranny Pan
Dynotech Metal Matrix Rear Drive Shaft
Redline Axle Lubricant in both axles
Aluminum rear diff cover w/ caps support
Flex-A-Form rear mono leafs
Suspension Techniques Sway Rear Sway Bar
Hal QA1 Adjustable shocks
Energy Suspension:
-Body/Cab Mounts
-Tranny Mount
-Upper & Lower Control Arm bushings with zerk fittings
-Front and rear sway bar bushings
-Leaf spring and frame shackle bushings
-Front Bump stops
Baer PBR calipers & 12 inch rotors up front
Front & rear drive shaft loops
Firestone SZ-50 EP 245 50 16 tires
Chevy Extreme/SS bed frame crossbrace
Autometer Tranny Temp Gauge
Autometer Boost Guage
ATR Air/Fuel Meter
Sparco Driver Seat
Hella Vision Plus Headlamps
Sylvania Siverstar Bulbs
Hella Micro FF Fog Lams
PIAA Fog Lamp Super White Bulbs
Throttle Body Air Foil
Optima Battery
Kenne Bell Battery Fenderwell Kit
Spare Tire, spare tire mount and jack removed
