SyTyAddict
Is there any significance with the exact number 12.66* kr? I know that if the knock sensor is bad or unplugged it defaults to 4.04* The first time I launched the Sy it maxed at 12.66*, but strangely this was at about 20% throttle and still under vacuum, after it went into boost and throughout the run it leveled out to about 8-10*. Any time it goes to a high kr # it also maxes exactly 12.66* and will do it every time I log it, but it has never surpassed 12.66*. I was having issues with kr at idle (up to about 5*), but I have eliminated that issue be reseating the ribbon cable from the prompaq, it was slightly loose. I have occasionally seen it hit .5* at idle, but that rarely happens.
I know that that is a lot of knock and I've only gone WOT about 3 times, I am not getting into boost anymore until I get this figured out. The way it acts, it ,makes me wonder if its not an issue with the ecm or the chip. I plan to go code59 soon, but would like to try to figure this issue out before I do that.
Thanks,
Clay
Thanks,
Clay
