I've given my GT to my son for his first vehicle... the steering feel is pretty vague. I can hold my finger at the joint between the pitman arm and center link and I can feel them moving differently when the steering wheel is wiggled, but the truck actually turns with a very small wheel input so I'm pretty sure the steering column and all of that is ok, but the feeling is still very vague. This doesn't inspire confidence with a new driver. I think it has about 120K miles on it.
I'm pretty sure it needs a new Pitman arm and idler arm. I purchased both but apparently didn't look close enough and I got the wrong parts. After looking into the issue closer (after pulling the idler arm...) I find that the pitman arm is ~$140 and the correct Idler is a fairly normal price (like $15-40).
My question really comes down to this...
Is there a better solution to replacing these parts (maybe including the center link?) so that I don't need to purchase the $140 pitman arm? Right now the idler and pitman locations on the center link have the joint posts on the center link, and the actual idler arm and pitman arm have the hole. Center link is male, arms are female essentially. This seems to be uncommon on the S-10 style trucks? I'm not sure as I'm not a mechanic by profession. Though I do tend to do all my own work on my bikes and vehicles. Either way...
Is there a better way to go about solving the problem?
If there are pitman, idler and center link parts that are direct swaps but will also replace the joints while at the same time making them easier to replace next time... I wouldn't mind doing that. If not... Is there a less expensive Pitman arm?
Thanks in advance for your time.
