spark plug gap
Slyclone
Well-known member
I am wondering what the best gap is for the spark plugs.
Only reason I'm asking is I just did plugs... And my veci sticker says .035 and my blue service supplement pg 6D4-2 says .045
Slyclone
Well-known member
Re: spark plug gap
I'm starting to discover the truck has some mods.
So far 40# injection, egr delete, had air intake. I need to investigate and see what type of chip it has, because it is obviously calibrated to run egr delete and on the 40# injectors.
I gapped them at .035 but seen in the manual and was wondering why there is 2 different specs.
The truck smells like gas bad when running. Very fuely
Syclone22
Re: spark plug gap
You can also install an air fuel ratio meter this will be a
good starting point to see if your tune is running on the
rich site ..
Re: spark plug gap
I looked the Syclone supplement and sure enough it says 0.045. It should be 0.035 and I am guessing the service manual supplement is a mistake.
For a 100 % stock truck I usually set it to 0.035; for an engine with higher boost and colder plugs I usually set it to 0.032. The lower spark plug gaps 0.025 to 0.030 that you will see on this site is only needed with with alky injection.
