Silverblaz @ the track
silverblaz
I'm on my I phone right now just did my first pass 2wd dontforget with street tires just ran 12.16 @ 114 with a 2.0 60ft
R&C_RallySyTy
Little Big Man
Re: Silverblaz @ the track
That's not bad at all. Congrats! The best part about it is normally you can improve a few tenths after your first run. Could possibly see a high 11! When you say 2wd do you mean RWD or FWD?
silverblaz
Know I should not even answer this but RWD!
All in all the day was good cold but good got 2 passes second pass was 12.2 @114 same as first 2.0 60ft and 2nd gear blows the tires right off haha.
I will post the videos soon very little knock on runs most of it is noise not real but the boost peaked a little In high rpm was running 20lbs but saw a peak of 23 at one point
Thanks goes out to Nolan for tuning the truck from half way across the country
Very Impressive for a 2WD truck (knocking on 11's would be impressive even for AWD). Have you done anything to the suspension to help with traction?
silverblaz
I have qa1s up front with 650lb springs so not raceing spring rate haha just for driving.
I have beltech leafs in the back that's about all.
Mind you I do have a full interior with sterio fiberglassed in all around. so truck and me are 3600lbs, I can't remember what the split front to back was but nothing special tires are 18x8 eagle alloy 30lb rims haha, 235/50/18 kdws like I said nothing special
i8av8
x2 :rotf:
very nice run! what was your tire pressure at?
i was a measly 12.7 @ 111 compared to your 12.16 @ 114. i also don't have a tune, though. need to get me one of those. again, good job :tup:
R&C_RallySyTy
Little Big Man
I hate it when people can't see sarcasm in writing. :roll: Who would really make a blazer FWD for drag racing? :rotf:
