Re: Running Rich In Mempho
I'm fighting the same thing with my typhoon right now it's running really rich.I was just wondering had did you do a leak down test on the injectors?
Syclone1514 said:Bummed. Just did a leak down on injectors - No leakage. Put 2Bar and stock memcal back in - no change. Put in new Bosch 02 - no change. Checked again for vacuum leaks - no leaks found.
Here is what I found: The green connector on the back of the ECU- when I wiggle itwires just right I can make the truck die. Must be something with the connector. How do you get the pins out? Is there a special tool?
Frustrated in Mempho !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
