mhoover said:
Ed, look at that ET gap between you and stroker boys (Robert, Les) though (and the oddfire goofball).
ok im confused? who is "the oddfire goofball?"
MATT
You (and Doc) and Ryan are the only oddfire goofballs I can think of.
I just dont know how to compare oddfire to evenfire. Displacement for displacement I would not expect evenfire to be very far behind oddfire. I would expect very little difference between them (I am not aware that the firing sequence explicitly contributes to more power in oddfires). I dont know how much boost you run but is it well over the 25psi very fast evenfires are running?
My point is this: given an oddfire and evenfire with the "same" cam and heads and turbo and such, I would not expect there to be much difference, for a given level of boost, between the power generated by each engine.
So I would like to think that it does NOT take a stroker motor to break into the 9's, using you as an example, but I cant be sure that there is something I dont know about oddfires that makes them inherently more powerful.
