InvisiBill
Also, the EGR dumping exhaust into your intake gets crap all over, which can increase knock. You should run some Top End Cleaner through it once you disable/remove the EGR to clean it out good. There's a howto up, at SyTyArchives.com I think.
If you have the stock chip, you will get the Check Engine light sometimes. The EGR test works by turning on EGR and watching for a reduction in fueling (due to the reduction in volume of oxygen). It actually watches for the results from opening the valve, so the only way for the test to not fail is for EGR to be working (i.e. you can't block off the EGR passages but leave the valve hooked up or something to fool it). I've had my EGR disabled for a year and a half or so on the stock chip, and I've seen the CEL maybe half a dozen times. While the CEL is on, it does limit boost.
If you want a quick test, just unplug the vac line from the EGR valve and plug it. It's obviously not as good as blocking the passage at the head and the valve could still leak, but at least you're not specifically dumping exhaust into your intake. Like others, I saw at least a 60 degree drop in IAT just by unplugging the EGR vac line.
