Parts F/S
Slyclone
Well-known member
Brand new never used TCI 700R 4l60 Cast Alum. Deep Trans pan PN 378000 I believe it is a additional 2 qt. Also have a additional TCI thick rubber gasket and racing filter for high heat applications PN 378500. The large gasket shown is NOT the gasket. Thats a cheap paper thin one not included. Was just in the box..Asking $185 shipped.
Have a Tubular cross member I am not using asking $150 shipped
Also have a low mile typhoon driveshaft in case anyone needs one for a transfer case conversion on a syclone. Asking $75
Thanks
T-Bone
Re: Parts F/S
Dibs on the new TCI aluminum pan.
Is the tubular x-member for a 700R4? If so, interested in that too.
Slyclone
Well-known member
Re: Parts F/S
Transmission cross member is for a 80e.
I believe the bolt holes in the mount are a little differently spaced.
Sy1566
Re: Parts F/S
Just out of curiosity, what's the difference between a Syclone propshaft and a Typhoon propshaft?
Slyclone
Well-known member
Re: Parts F/S
Its a driveshaft. Not propshaft. I got a few inquiries on it.. Being a propshaft? It says driveshaft. Rear driveshaft. If you convert to a upgraded larger spline typhoon style transfer case ( in a syclone) the driveshaft would be the correct length. No B/S figuring stuff out length wise.:tup:
Slyclone
Well-known member
Re: Parts F/S
bump $160 for pan+gasket/filter
Slyclone
Well-known member
Re: Parts F/S
Bump for Trans Pan, Will work on 4l60,4l60e,4l65e as well as the 4l70e (trailblazer ss)
