spooldup
Super Member
Ok here goes. I have searched on here and read a million posts and drank many beers thanks to ed's posts.
but my problem is still here and seems to be getting worse. My truck runs perfect until fully warmed up and then the idle hunts from 625-950. If i give it a quick tap on the gas pedal and let go it stalls. If i try to restart it right away it doesn't start. I assume it's rich? I can't use the s terms on dm because it does not work right on my truck for some reason. I had the fp set at 50 and it ran great for a day or two and then all hell broke loose. I had to double foot it home. I then lowered it to 47 and it was good for a day or two until you guessed it all hell broke loose. When i am driving around and come up to a light it can't control the idle. When the car downshifts for the light or whatever the idle drops down to like 500 and then up to 900 very rapidly back and forth. It seems like it's trying to corret it's self but is changing so dramatically, 96% of the time it can't recover and then just dies while i'm moving. I have new wires, cap, rotor, plugs gapped correctly, fuel filter, walbro, vac lines, pcv, iac adjusted to 32, coolent temp sensor, new 50lb pte's, intakes cleaned, perfect compression, no oil consumption, and not a clue as to why it's like this. I also metered the coil wich checked out good. I have dm files if it helps. I am currently waiting for my 2 bar map to get here so i can try the pitbull chip and the stocker to see if it helps only idling of course. The only thing left is the distributer. I don't know how to time a car so i am skeptical to mess with it. :-?
