oil pump and oil pump shaft question?
ed hess
race or get outta the way
again since this motor wasnt oem when i took it apart, you will understand my reasons for these questions.
The new oil pump comes with a white nylon bushing about a inch or so long and 1/2 wide, cylindrical in shape with a steped id of maybe 1/4 inch eyeballing all the dimensions.
The oil pump shaft that came out of this had a metal collar around the oil pump end that was held on to the shaft with a a rollpin.
they told me this was not the oem shaft.
is this correct?
The shop next to mine tells me i dont need the nylon piece since the collar on the shaft does the same thing.
Is this correct?
Also i had puchased another shaft from arp but the arp unit doesn't seem to fit into the oil pump shaft as well. the arp unit looks like the male rectangular end is a bit smaller that the unit that came out of this motor.
The result of this is that the arp shaft can wiggle more so i was thinking i should simply stay with the shaft this came with?
also when i removed the pump from the top of the no 4 main bearing cap there was no gasket or seal of any kind between the 2.
Should there have been.?
The service manual doesnt show one either.
I havent checked the fit with prussian blue yet but i will if this is supposed to be metal to metal on the pump to main sealing faces.
ed
Sy769
Use the shaft with the metal collar if it is in good shape -Don't need the nylon piece.
Oil pump mounts without a gasket.
ed hess
done
Ya know i love this place. Started out between a rock and a hard place cuz i hadnt planned on doing this myself although i knew i could. And you guys have been priceless in helping me out with my questions.
Good news is Im halfway done. all i need now is my heads back from the machine shop and i can get on with the top end!
ed
ed hess
it was melling no m55a.
Dont forget to weld the pickup tube onto the oil pump cover housing.
retorque cover to 80 inch lbs. also remove spring before you weld it.
springs dont go well with high heat. it changes their rate.
ed
