The trans idea may be a bit much to try and tackle during this meet, so I'm not so sure it'd be a good idea.
I'm also considering just pulling the valve body off my spare trans, overhauling it and swapping out the one on the truck.
Reason is, I drove the truck today and it still has good strong shifts, fluid is fresh (less than 200 mi) and it doensn't smell burnt.
So I'm considering just trying an overhauled valvebody, because it could be something like a sticking valve. I'll probably just re-use everything as far as valves/springs go. I'd like to go ahead and replace the cheap little parts, like the pressure switch and anything that looks damaged/warn. Obviously I'm going to need gaskets, etc. and should probably eliminate the TV exhaust check ball.
Sorry for going off topic a bit, just wanted to explain my reasons if the bringing the whole project down there is a bit too much.
later,
