SYCLONE#1531
'MOFOFAST
I went to Silver Dollar dragway today. I ran a pretty good time but it seemed like theirs alot left in it. Truck was running 25psi 26 degrees of timing. All stock longblock. Im running a lockup 9.5 2800 convertor , 60lb injectors, PTB 61mm / .85 ex turbo / 3 inch downpipe back/ FMIC/ C16 tune by RPM. AC DELETE / RPM FANS. Conv locked with KB switch. I cant get it to 60ft worth crap! 1.8s Once out of the HOLE,your pinned to the seat the whole track. ALSO, Intake was heat soaked on this run. Truck was also running about 190 degress. Its time for a aftermarket radiator. Is their anything I can do to get this thing to spool up off the line. SMALLER EX HOUSING? Aprox 5/6 LBs is my max!!! 2600/2700 on the brakes. Temps outside were in the low 80s which didnt help any.. I was hoping for some lower 11s out of it! Any suggestions would be much appreciated..
