my first ty finally
Finallyaty
Just bought my first typhoon.
Have wanted on since they came out but my wife and money would not allow it.
My ty is just as sweet as I thought it would be 15 years ago.
Pertti K
Re: my first ty finally
I quess you now had the money, but what happened to your wife? :rotf:
Anyway, congratulations for the purchase! :tup:
Baythan
SY2TY2SY2TY
Details! Location, mileage, color, year, last 4 digits of vin, etc. :tup:
Finallyaty
I'm in MN I bought a 1993 black on black typhoon #1109
It has 94,### miles on it but looks really good except it is missing
Pass side moulding behind the rear wheel.
So far I have put both new lower ball joints in and a new idler arm.
new cap, rotor, plugs, and msd 8.5 wires
new front sway bar bushings and a 1" rear sway bar.
I really want to get the handling great before I do much more to the motor.
It seams to run strong after the tuneup.
Any good suggestions on suspension and steering improvements short of IFS?
I
Loeryder
Congrats on the Ty!
You are started on the right foot.
Get it running smooth first, then faster later.
A Zq8 steering gear (faster ratio) and a new steering shaft, preferably a borgensen w/needle bearings.
Rear sway bar and if you have the original shocks they are worn out. If th efront suspension has been rebuilt yet, the ball joints will all be worn out (you can tell if its been rebuilt by looking if the ball joints are bolted in, the originals are riveted)
Finallyaty
Loeryder said:
Congrats on the Ty!
I'm New to this, can you steer me in the right direction for the steering gear and shaft.
I plan to
Front : Moog Upper and lower ball joints.
Moog idler arm tie rod ends
Energy suspension bushing Upper control and lower
Rear: energy susp bushings
New shocks
Already installed sway bar (huge difference)
Any recomendations on shocks. I would like to keep stock height. I live in snow country.
z24turbo93
Was this the one at Denny Hecker's in Stillwater? If not, does anyone know what happened to that one?
gjp
another post whore
welcome. check the forums on the Zq8 and steering shaft. Bolt on mods.
Get a scan tool too. while you have the front spindles off it would be a good time to do a brake upgrade.
I plan to
New shocks
You can swap in a Jeep shaft for cheap or buy an expensive Borgeson shaft.
here's a little on the Jeep shaft.
For those who know and frequent any S-10 forums they will learn that the steering shaft of a Jeep fits the S-10's. The Jeep however uses 2 universal joints on the shaft which means it has zero play. The S-10 shaft is a joke in comparison. The upper joint is a U joint but the lower is a sloppy rag joint which uses a rubber disk to act as a flexible joint. GM has used them for year on pretty much every vehicle that uses recirculating ball steering systems. If you are looking for an improvement in steering feel and elimination of any slop this is the way to go. You can buy more expensive shafts from companies like Flaming River. But they money spent is mostly on chrome. Granted the shafts are nice and well built, but a Jeep shaft costs fractions of that in the junkyard. I paid $30 for mine. If you do this swap you are looking for a late model Jeep Cherokee.
Here is a simple comparison. The S-10 shaft is the top one. Notice the rag joint on the left side. Also notice the ugly plastic cover GM uses to hide it. The lower is the Jeep shaft. the jeep shaft I got also has a boot protecting the collapsible shaft so water and dirt cant get between it. This is a picture of the upper joint attached to the steering column.
Here is the lower joint which is the main reason for this swap. The elimination of the rag joint is the best thing you can do for steering feedback.
The joint I got was from a late model Jeep Cherokee around 1999 to 2002. On this one you will notice the clamp style upper joint. It is not the same as the S-10 upper joint but it is not a big deal. All you have to do is grind a small divot is the steering column shaft of the S-10's and then it is all a bolt on.
fronzo
FTT Customs
Thats a nice tip with the steering there. congrats and good luck on your purchase!
z24turbo93
I was just wondering. If it was still sitting there in a couple months i prolly would have picked it up. The members on this forum said it was a very good truck. Enjoy!
AUSyTyIN
Unbusted $#it box
midnightbluS10 said:
check the last two sentences.
Ummm...., ok. That doesn't tell me nada.
So it was right before that.
