Moroso breather/catch can
Slyclone
Well-known member
Used moroso catch can with breather. Alum can has some scuffs on surface ( sticker was getting scratched so I put clear tape over it)
I used this on my syclone when I changed things around.
I am obviously changing things around again.
It had a monster AN fitting on it and I bought what ever it was to step it down to 10AN... Large blue fitting alone was about $30...
$65 shipped.
atkonkler
Is this your bush?
Re: Moroso breather/catch can
How was this routed in line with the PCV system? Was it used on the 4.3l?
Slyclone
Well-known member
I welded a 10AN steel fitting to the driver side valve cover. I 90ed out of that and straight into the can. The can was placed up front by head lamp area. I connected with a short piece of stainless 10AN braided hose.
I utilized my OEM pcv stuff into the intake. Just got plumbed in to the intake system..
This was used on 4.3. I bought it, and incorporated into the engine bay. Not sure if I have a photo of it I could dig around
(I dug around for you and found a pic you can see the hose right next to the oil fill tube, and the can located up towards the front.. It even says " moroso " for easy ID.)
IRVIN COLON
Post picture of the install in both valve covers and moroso breather, i will like to do that setup thank
Slyclone
Well-known member
Bump, I'll throw in the valve cover with welded AN fitting, and short piece of 10AN hose with the 90* end and strait fitting for $75.
Cleaning up, have new eyes. Seeing differently now.
