Misc. parts F/S
Slyclone
Well-known member
Couple parts I have for sale not using,
1- Tie rod end ( perfect circle brand) new in box $25
1- Ball joint ( RK 5289) new in box $10
1- Pair rear break shoes ( assuming typhoon) no hardware/springs still sealed. $30.
1- Moog problem solver pitman arm ( K6339) GM new never used $35
5- Original sy-ty " black " injector clips $15
12-Front bumper rivit spacers 2 sets. $10
1-Used bumper support bar good condition $15
1- Frame horn bracket ( broke ) with hardware $10
Slyclone
Well-known member
Re: Misc. parts F/S
Blue, should have been clearer its a front bumper support bar extends off the frame to the bumper support. Small tubular bar.
Slyclone
Well-known member
Re: Misc. parts F/S
Also have :
1 alternator support/fork bracket. Supports the alternator. Connects to the P/S pump and exhaust manifold. $35
1- Used clutch/fan assembly. Clutch mechanism could be bad, fan blade is removable and can bolt on to another good clutch mechanism if this one is bad.light surface rust. $30
1- New in box CV boot repair kit. 1 boot, 2 special clamps and a packet of grease. $20
1- AC Delco OEM 1993 Typhoon take off alternator. Good working unit. $50
Slyclone
Well-known member
Re: Misc. parts F/S
Couple other things
Front syty wheel. Bent. Stripped all the clear off. Needs to be straight. Not cracked.
Syty front rad support.
Sy1566
Re: Misc. parts F/S
Hello,
I'll take the:
1-Alternator support/fork bracket. Connects to the P/S pump and exhaust manifold. $35
Please PM me your PayPal address. Thanks
Slyclone
Well-known member
Re: Misc. parts F/S
You going to Carlisle?
I'll be loading my truck tonight/tomorrow with some items I plan on selling.
I will set the items aside for you if not.
