Milan dragway this Sun.???
KDBL1TY
Re: Milan dragway this Sun.???
I made a few calls around. Im still getting my TY back drivable. Almost most certain Im headed that way Sunday.
attackdog
Good stuff! The weather is suppossed to be nice. See you all there.
-Dean
1madgumby
Had A good time today. IM sure everyone else did also. ran 12.22 @ 111 was the best. Kinda disapointed but stayed together to drive it home so I can't complain to much. I have to get A larger fuel pump, running out of fuel half track. but all in all A good time, can't wait to do it agin .
KDBL1TY
Had a good time. Weather was perfect. Cant wait until Im able to run again.
qbnkiller
Conflaguration Specialist
I am planning on being at Martin US-131 dragway on Saturday November 7 (weather permitting). 12-4. This is a very nice track, and should be nice and cool for some good times.
Now that I have the truck running good, hoping to lay down a fast pass or two (and get thrown out).
AJ....did you hurt your truck? 12.22@111 with the front prop shaft in or out?
1madgumby
Did not hurt it. prop was in 1.7 60'. I cant make it to us 131. I would love to but can't
Big Mike
Tell us what you did to run that time, how much boost, what total timing, fuel pressure, how much boost at line, any knock, any methanol or race gas, how about some info on your set up.
1madgumby
To much to list. good tune & A good working fuel pump will be in the vary low 11's if not 10.99999 20 psi on top end. 29 deg timming 55 psi fuel not sure on the knock no meth 110 octane turbo blue
Big Mike
Really 29 degrees of timing. Looks like your going in the right direction keep up the good work, what size injectors and what fuel pump are you running, are you locking up your converter if so what gear?
1madgumby
75lbs, walrbo 255 ( not enough I guess or A bad pump ) its A lock up converter , not sure what gear(S)
Big Mike
So are you going to add a second pump? What makes you think the pump is bad or not enough? What is your base fuel pressure?
1madgumby
Second fuel pump would be A little eaiser then A A1000 install, Not saying its bad, just something going on the were its not keeping up. base FP is 55psi running 20 psi.
