Im getting low oil pressure on the ty. When I first start it, it has good pressure sits halfway on the gauge 40psi I believe? Up to normal operating temp it is good, then when I start driving for 10 min. or so the oil pressure starts to drop to the 1/4 mark and it sits there...so far I have checked the plugs to see if there is any oil residue doesn't appear to be any, are there any tests I can perform to start narrowing down the possible causes? oil leak in valvetrain? bad pump? etc.
Also it keeps spitting out a IAC error code even though I just installed a new one...and it runs rich and starts idling high 1000 RPM after 10 min. or so of driving. I've tried pulling the ECM B fuse lots of times no luck
