liquidswords88
I pity da fool
I just got done getting the engine my ty rebuilt. Balanced rotating assembly the whole 9 yards. Long story short I had to use flat top Pistons. I also changed out the heads for a set of l35. I port matched the manifold and the turbo as well. I also went to a 3inch "Jsm" style down pipe and three inch exhaust. The compression ratio ended up around 9.75 to 1. I know this is not boost friendly or pump gas friendly. Before all this work I bought a turbo tweak chip from a gentleman whose name I believe is Eric. The chip was burnt as a stock 92 octane chip. I expected the truck to be lean but was going to turn up the fuel with the chip to its max. Doing that makes no difference. I have been around tinkering with engines long enough to know a lean misfire. The plugs are lean as well. I know the misfire is not ignition related. Everything is new and quality parts. Msd,ngk ur6 plugs, new distributor, gm ignition module, real nice wires that were made for a group purchase for here a awhile ago. New harmonic balancer, blah blah blah. Everything on this truck is brand new.
What do I need to do to get this thing more fuel? Are my stock injectors going to be enough. I am pretty sure my chip can be burnt with a different tune. I am really frustrated with this damn truck. I have datamaster and there is no knock when the misfire occurs. Everything else looks really good. Sorry for the long post just trying to include all the info.
