Re: Knock
It's a FAST system, the old-style, (not XFI) but I can certainly post a log if you'd like to look at it.
I checked the timing about two weeks ago, and it was right on with what the FAST thought it was.
I checked the fuel pressure about a week ago, it was about 50 static, and goes up appropriately with boost. I've tried fuel pressures between 45 and 55 static, with no difference.
I've just replaced the plugs with Autolite 103s. The old plugs didn't actually look bad, they had a bit of grayish stuff on them, and a bit of black. The truck has been run pretty rich in the past month or so, so it doesn't surprise me.
The 135 I got on 3 cylinders, it was getting dark and the air mosquito-filled. The engine was pretty cold at the time, if that makes a difference. But it was consistent across the 3.
The boost display between the MSBC unit and the FAST agrees, so I think the MAP sensor is ok. I will re-check the MAP part number just to be sure though.
The MSBC won't let me run anything less than 10 psi. If I recall correctly, that doesn't ping, but I will try it tonight and see.
I flushed the cooling system about a month ago, and carefully filled it, and burped air out of it for a week. It runs 165 degrees, and pretty much just sits there. It's never seemed to run hot, and never boiled over or anything.
Oh, and the O2 sensor is definitely a wide-band, but I can't say that I know it's in perfect shape, since its 4 years old. It does show appropriate swings in voltage when you force it lean or rich, though, and when turned on, closed loop does add and subtract fuel. If it was stuck at a particular voltage, I'd expect it would endlessly try to lean or richen the mixture.
Thank you again for the input. If I don't get frustrated enough to sell it to the junkyard, I might try converting it to E85. If it pings THEN, I know I've got problems.
