Usually hard to find used. PTE as them for around $150. Expect to pay close to that for a used one.
John
[[/b]
Hi John thanks for this info i did ask Mike at RPM
but he said we can only purchase a complete turbo
i was considering working with the guys at Comp turbo
there turbo has triple ball bearings last year i paid them a
deposit to build me one with the PTE housing but later after
4 months they could not fit a PTE housing to get the build done !!
Do you know where i can purchase one new ??? :roll:
Call PTE direct. I just picked one up last fall.
John
John
John
I spoke to PTE today and they have the new turbine
housings in stock but only for there new PT turbine wheels
the sales Tech also told me that the old PTE housing had
a different bolt pattern and downpipe are you aware of this
some feedback will be great before i order this !!!![]()
I been chatting with Arron @ PTE. They did discontinue the Old housing and are offering a new style.
I just purchase a PTE 6152 and heres what I was told
"The "E" is the compressor cover style, which is a 3" inlet and 2" discharge compressor cover. The 6152 unit has been discontinued and there are no upgrades available for this unit."
I asked if I can upgrade my hot housing with a newer anti surge compressor. Response was as follows
The 6152 unit was rated to support 630 Flywheel HP. It has a 61mm cast compressor wheel and a 62mm T350 turbine wheel. The PTE Syclone housing are used only with our older PTE downpipes. If you have our down pipe and are putting it on a Syclone then it should work. Since we no longer make that unit and cannot upgrade it, there is nothing to be changed on the unit!
My turbo is still good. I was just looking into there cold side housing and wanted to know what it would take to put a newer/larger housing.
Best bet is try out there new products.
i have a old pte housing with a custom built bullseye billet 66m and race cover in it brand new im looking to get rid of..pm me if your interested.
