Injector impedence? Please explane.!!
1madgumby
Can anyone explane what injector impedence is? i see there is A high & A low. Not sure what this means. I know I need 75lb. injectors. Just want to make sure I get the right ones. one is $65 ea. & the High is $99.00 ea.
Thanks!
Beavis
Still plays with trucks
Re: Injector impedence? Please explane.!!
impedence = resistence basicly lower resistance without the proper drivers will overheat and burn up. They are in the ECM, and are a hardware component. :2cents:
SCWolverine
If you don't want to "mod" (upgrade) the ECM, go with the highs. As mentioned, using the "lows" will require different drivers to handle the load.
jabberwalk
Is there a reason to choose one over another (performance or reliability wise)?
Up until recently 50# was the biggest high impedence available. So if you needed more fuel you had to go to low imp. stuff.
Now there is theory that low imp. injectors can open faster. It does require mods to ECM to be able to handle the amps needed in low imp. stuff.
Honestly if you can get away with high imp. stuff to avoid ecm mods do it.
1madgumby
Here is my build.
RPM lower intake setup
Ported heads (2.02 1.60 valves)
comp cam 412 cam.
eagle h-beam rods
nitrioted stock crank
JE Heavy duty pistons
58mm. throttle body.
TE-72 turbo
4" downpipe. no muffler no cat.
will need A custom chip made to order :)
So with that said What injectors??
Aj.
