IAT Sensor Scaling
Aeroking
e.i.
Can somebody confirm if the IAT sensor resistance scaling is the same as the CTS? I measured them the same at current ambient temps, but i am looking for someone to confirm.
Thank you.
Re: IAT Sensor Scaling
Looking at the manual the MAT (as the manual calls it, Manifold Air Temp) Low temp produces high resistance, high produces low. 100,000 ohms at -40*, 70 ohms at 130* Best I can do at the moment, Might be able to figure it from there with a pot of hot water and cooking thermometer.
Eric Sy GN
Yes they are the same. At room temp, say 70* F, you should be seeing around 3400 ohms for both sensors.
Aeroking
e.i.
thanks guys.
I have checked it a couple times at ambient 40deg 7350ohm, and 60deg 4600 ohm.
Both times, the IAT and CTS were close. But i wanted to verify first, because it will be difficult once the engine is running (intake heat soak).
I know a typical GM scaling is 30-100k ohms for some temp sensors. My readings align with that, so that's what i am calibrating too.
Thanks again.
Aeroking
e.i.
this was the scale google showed. I'll follow it, then fine tune later.
I was in a hurry this AM so only posted what I did to get you going.
Aeroking
e.i.
Thanks for the info Don.
The CTS sensor is easy to check with a laser heat gun on the probe. But the IAT will be tough. So as long as both sensors use the same resistance scale, I can use the CTS calibration for both sensors.
:tup:
:tup:
Didn't help much but you're welcome. The difference is the IAT thermister is exposed. Faster reaction I imagine. You might use the hot water trick but that's as far as I would go. A heat gun might toast the thing. Put it in front of a heater vent in your house and see what that does...:roll:
Aeroking
e.i.
I meant laser thermometer. Not a heat gun. You can put a thermometer on the CTS housing and get a reading. Since the IAT element is sort of free floating, it would be tougher to get a reading on it.
