I need a tuner, St Louis MO
Drew-py
I am in need of someone that can tune my truck or information to a good tuning shop. I am running the stock ECU with a Turbo tweak chip, Scan Master 3, Wide Band 02, 422 cam, 1.6 rockers, twin 58 mm TB, ported intake, ported L35 heads with 2.02/1.60 valves, 60 lbs injectors, HX 35 turbo with external waste gate and manual boost controller, 2800 stall.
I have the idle and drive ability dialed in pretty good she will start with auto start remote with out stalling, has, a slight surge when coming down from driving speeds but smooths out quickly. Only stalled once or twice at low speed, under 5mph , coming off of speed while heavy braking and turning (hydro boost brakes, power steering and that little surge).
That pretty much sums up the power plant upgrades. Any help is very appreciated.
Eric Sy GN
Re: I need a tuner, St Louis MO
If you can take some logs, I can look them over and see what adjustments might need to be made.
Eric
Drew-py
Eric
I have no logging ability (no laptop) which is why I need some one I can take the truck to. If you are willing to tune it for me. I can trailer it to your location and do some street tuning if you want to set up a time, and let me know your fees. Thanks
