boost junkie
I'm buying an HRC super 20G turbo. I'm trying to sort out their turbo options. I happen to have 2 turbine housings sitting in the garage.
8cm : 79-12100
14cm : 79-14300
The 14 is WAY too big for me since I'll be using this on a 2.0L neon engine. I think the 8cm will be just right. Here's my question. HRC has 3 different 20G's available. The regular 20G, 20G-H and the 20G-N (cant find any other info on that one).
20G: (the turbo I'm buying)
TDO6H20G-TDO5H10CM2
Max. CFM: 680
Compressor Inducer / Major Diameter: 2.075" / 2.675"
Turbine Exducer / Major Diameter: 1.930" / 2.200"
http://www.hahnracecraft.com/hahn/parts/s20g.htm
20G-H (The turbo I want to build)
TDO6H20G-TDO6-8CM2
Max. CFM: 680
Turbine Exducer / Major Diameter: 2.175" / 2.560"
http://www.hahnracecraft.com/hahn/parts/s20gh.htm
20G-N (N wheel???)
TDO6H20G-TDO6H10CM2
Max. CFM: 720
Turbine Exducer / Major Diameter: 2.315" / 2.650"
http://www.hahnracecraft.com/hahn/parts/s20gn.htm
Ok, sorry for the long post, but basically I want to convert my TD05H10CM2 turbine to the 8cm turbine I have in my garage. Oh, you might want to know the goals. 400whp from a 2.0L on race gas.
Can anyone identify what wheels those are by the in/ex diameters?
Should I just stick an H wheel in my 8cm housing?
Is my 8cm turbine housing a td06?
thanks
8cm : 79-12100
14cm : 79-14300
TDO6H20G-TDO5H10CM2
Max. CFM: 680
TDO6H20G-TDO6-8CM2
Max. CFM: 680
20G-N (N wheel???)
TDO6H20G-TDO6H10CM2
Max. CFM: 720
thanks
