help disconnecting rear speaker
escofield
Just got my stereo installed and the passenger rear speaker isn't working. How do you disconnect the plugs?
escofield
Re: help disconnecting rear speaker
push down on the little tab and slide it off
OK.. talk to me like I'm an Idiot, what tab? There are blue caps on the top of the connector that slide off, but i cant see any tabs?
Sorry for the bad pics, iPhone/bad light
Thanks
GM TURBO
Sell Out
I'm guessing this isn't your problem.
There is a connector on the driver's side floor that will come loose (I've seen it on mine and one other truck). I'd run an ohm meter front to back before replacing the speaker. I've never seen a bad speaker not make some noise.
escofield
Thanks, I'm trying to figure out the problem, whether in the wires or the harness. About to hook up the ohm meter
escofield
I removed the stereo and the harness, connected the ohm meter to the speaker plug and went thru the harness plug and found the right wire, then i plugged in the stereo harness and traced it down making sure all the connections were good all the way to the end that plugs into the headunit. Good readings all the way down the line.. for both positive and negative. do I have a bad head unit?
GM TURBO
Sell Out
Damn - maybe it is a bad speaker - lol. What about popping the drivers side speaker out just for fun.
You mentioned it was a new stereo - or just installed? Are you running through an amp? Balance is set correct :)
escofield
You mentioned it was a new stereo - or just installed? Are you running through an amp? Balance is set correct :)[
Bought it and installed it yesterday
Before i disconnected everything I swapped the drivers and passenger speakers, still nothing on the passenger side. the balance was at 0 and so was the fade before i popped it out. Gonna put it all back together just to see what happens, then take the head unit back i guess?
escofield
Hooked it all back up.. still not working. back to BadBuy to see if they can test the head unit
