front propshaft bolt size?
elorejas
Well my friend got 92 typhoon 0325 and it didn't have front shaft I have one laying round just don't know the bolt size to guy buy some to put front shaft on.
RealFastV6
@jb_and_his_coffee
Re: front propshaft bolt size?
PM SY2932
"Grade 10.9 (150,000 psi tensile strength) hex head bolts, M10-1.50X25mm front and M12-1.75X25mm rear, direct replacement for stock E12 (front) and E14 (rear) prop shaft bolts. includes Loctite 242 removable threadlocker. $20 by money order or paypal please. Paypal addy is syclone2932@gmail.com"
SY2932
Administrator
Thanks for the plug :).
"Grade 10.9 (150,000 psi tensile strength) hex head bolts, M10-1.50X25mm front and M12-1.75X25mm rear, direct replacement for stock E12 (front) and E14 (rear) prop shaft bolts. includes Loctite 242 removable threadlocker. $20 by money order or paypal please. Paypal addy is syclone2932@gmail.com".
Davemc1963
93 Ty Owner
I know the bolts SY2932 sells are more than adequate for the job, without looking into the recommended torque settings, (which may actually answer my question), is there any advantage or disadvantage to using grade 12.9 bolts on the front shaft. It could be that the standard torque figures wouldn't stretch the 12.9.s enough. On my phone atm having family dinner out and getting "the look" from the missus, so will have to cut loose.
SY2932
Administrator
Torque for the front bolts is 75 Nm or 55 ft. lbs. It is 125 Nm or 92 ft lbs. for the rear ones. I don't see the benefit of a higher graded fastener in this application. The only thing that ruins these fasteners is people rounding them off. I have never heard of one failing (stock or otherwise) in the 13+ years that I have owned my truck.
Davemc1963
93 Ty Owner
Hi Mike, you are probably correct, I was just thinking about these when I come to change out my propshaft. I know we have some 12.9 cap heads at work which I could get for free. I presume these could be used in lieu of the Tx ones too.
roswald21
Do you have and extra set I need one asap
