Re: Front End write up...???
Just don't forget to loosen wheel hub nut.
I followed Chilton's manual, and ended up with tightened wheel hub nut, and with removed upper ball joint (and upper control arm, actually). And then it just says "now remove lower ball joint". Okay, but you'll soon understand that you need to remove the axle first. And omg, how am I gonna loosen the wheel nut without upper control arm?! I had to assemble everything back together. I almost burned the damn book
I could try to make a write-up for you, but except for ^^^ there won't be any problem, its kinda straightforward. Just remove everything, and then assemble it back
