external wastegate / BOV / ECm
Quickstop [UK]
Combating adversyty.
I have seen a lot of threads where people have suggested using the ECM to try and control external wastegates but this is deemed impractical.
Has anyone thought of using the ECM to control a BOV but only in the instance where knock occurs? So your external wastegate is controlling boost througout, but in the event of knock detected by the ECM , the BOV activates?
Any thoughts...just throwing it out there...
denny
Re: external wastegate / BOV / ECm
BOV is activated by vaccum :)
Denny
turbodig
Open BOV under boost = max turbo speed instantly. Dead turbo in short order.
I don't deem ECM control of the WG impractical at all. It's gonna get really compelling when we start integrating alky injection with knock detection and/or boost reductions under knock.
The ECM's WG knock control gets turned off too much. People don't want to fix their knock issues, so they buy an external controller and knock happily away... for a while.
Quickstop [UK]
You think? There are lots of people that have had hoses blow off after inatallation etc - that is the biggest BOV you could have! The reaction is immediately to back off...
That seems to be the natural progression - isn't the hardware out there to support this software? Sounds like it might be in a FAST setup or something?
I thought the knock controller pulled timing, or is that just an overboost condition? Could you not change the code so it pulled timing instead of allowing the knocking to continue?
The problem with knock is that it relies on the operator to back off - if you pull fueling, you run the risk of there being a very lean condition hence ka BOOM.
If you pull AIR, hence the turbo, then you end up rich and you lose power and back off - double safeguard.
Denny - you can run them off anything you like - this site is proof of the ingenuity out there! :D
denny
Denny - you can run them off anything you like - this site is proof of the ingenuity out there! :D[/QUOTE]
I would like to know how you make a BOV open under boost, unless it have a weak spring causing it to 'leak'.
Denny
Quickstop [UK]
I don't really know how they work so I'm not going to disagree - all I am saying is that someone that knows more about it than me might be able to get it to work.
Happy to admit that it's perhaps not the best of ideas!
:D
H-TOWN-TYPHOON
You're killin' me, Smalls
Are you referring to a pop off valve? Totally different animal. It's there to protect from danger to the manifold in case of an extreme overboost ie stuck wastegate.
NOJIMMY
wish I knew what that was, but in truth I think I just had a crap idea!!!
I don't know if I'm reading your posting correctly but thought I'd try to help.
There are a number of members on this site who can explain the following in detail:
(which are sometimes confused or mixed interchangingly).
a) internal vs external wastegates;
b) boost controllers (manual vs electronic); and
c) Pop Off Valves, Blow Off Valves, Dumps, Bypass Valves, manifold pressure relief valves and Super Sequential Blow Off Valves
About the last group however..... (and I may be wrong but here goes):
A blow off valve goes under many different names such as dump, bypass, recirc (short for recirculation), diverter, and pop off valves. No one term is correct, (I think) the lingo tends to change in different regions and countries and configurations. Basically these valves seem to all be designed to the same job, and I will refer to all types as blow-off valves to save confusion.
What it does: The only job a blow-off valve is supposed to perform is to relieve excess turbo pressure that results from shutting the throttle rapidly under boost conditions. It is necessary to release this pressure because it will try to find a way out of the system, and the only way is back out through the turbo. This produces a fluttering noise as the air passes backwards through the turbo, which is often unwanted. There is also a school of thought that a blow-off valve can improve turbocharger longevity or, in extreme cases, prevent damage to the turbo.
There are two ways in which the majority of blow-off valves work. Most aftermarket and many factory types use two pressure signals to determine when the valve should open. The other type uses only one pressure signal to open.
How it works: The usual arrangement is to have the pressure side of the valve attached to the pipe between the turbo and the throttle, and a vacuum hose on the top of the valve hooked up to the inlet manifold after the throttle body. A spring holds the valve shut. When you are on the throttle, the pressure in the turbo piping and the inlet manifold is equal, meaning that the pressure on each side of the valve is the same and therefore cancels itself out, leaving the spring holding the valve shut. When you lift off the throttle, you have high pressure in the turbo piping, and a vacuum in the inlet manifold. The pressure on the bottom of the valve and the vacuum on the top combine to lift the valve open and release the pressure in the turbo piping, since it can no longer go into the engine.
Blow-off valve myth #1: One of the biggest misconceptions about blow-off valves is that you need to tighten the internal spring to run higher boost. This is incorrect at full throttle, the pressure on the top and bottom of the valve is equal, therefore cancelling itself out. So no matter what boost pressure you run, the valve will stay shut.
Leaking factory valves: Having said that, some factory valves have systems designed into them to crack open at high boost, in order to protect the engine from boost spikes. They do this by designing the pressure to be unequal on the top an bottom of the valve, thereby overcoming the spring at a certain pressure. .
Blow-off valve myth #2: The fluttering sound is usually believed to be the blow-off valve. In reality, it is caused by a blow-off valve, but does not come from the blow-off valve. If the spring pre-load is adjusted too tight, this will cause compressor surge, which as described above is the sound of air exiting the turbo.
Compressor surge: You can think or surge as the point at which the compressor blades begin to "slip" in the air, losing their pumping ability, much like an aircraft wing loses its lift when it stalls. In a turbo, this happens in a series of bursts, as the blades slip, then bite, slip then bite. This sets up a pulsing wave in the turbo piping and explains why the sound has that characteristic "flutter".
The interesting thing about compressor surge is that it occurs much more readily at low turbo shaft speeds. At low shaft speeds, on street cars this is generally between 2000 and 3000 RPM, compressor surge is not much of a problem, as the loads generated by the surge are small compared to what the turbo encounters at high boost. However, if surge occurs at high RPM and boost, it is possible to reduce the turbo life and/or damage the compressor.
I do know in older Champ Cars the pop-off valve was simply a plate held in place by a strong spring. When too much pressure develops in the manifold, it pushed the plate up to release the pressure. Now Pop-off valves are electronic which keeps the playing field even (and the manifold pressures within the rules). CART provides each team with a manifold pressure relief, or pop-off valve, to put on top of their intake manifold. It's called a pop-off valve because it makes a loud pop when it lets off excess pressure. The effect is a sudden drop in horsepower. CART guards these valves, and goes to great lengths to make sure they are both accurate and consistent. Each day of practice, qualifying and racing, CART officials pass out the pop-off valves to the teams and collect them in the evening.
But as to your original posting...I have no idea how to include the ECM/electronic signal in this picture...
-Larry
denny
-Larry
I read that same thing here..
http://www.gofastbits.com.au/index.php?parentid=tech_info&option=tech_info
denny
