Re: EGR circuit
Without the tuning insight...
Typical failure for GM egr is that the Map sensor sees an increase with throttle tip-in. When the MAP increases, the EGR solenoid is opened, and vacuum flows, but without enough backpressure to allow the valve to open. As the EGR spring degrades, often times the EGR opens due to the weak spring and causes "my truck starts fine, but once I touch the throttle, it runs like crap at idle and dies". Pull EGR hose and see if it runs right. If it does, replace the EGR valve. Done it a hundred times. I've scoped it a bunch of times as well and it's clear that the MAP rises and immediately AFTER the EGR solenoid electrically is triggered on and then off with the touch of the pedal. With a bad EGR The EGR stays on because once the EGR is turned on momentarily and the EGR come on early the MAP stays low and the engine keeps EGR on because it thinks it should. A vicious cycle.
With that insight, I was thinking along the lines of factory meth injector control through the PCM. It's load based- you probably can control the duty cycle compared to MAP (load). My question (I have the tuning equipment for my rig, but the rig is getting bodywork done and no radiator to run it) is this: Does/Can the PCM call for increased EGR dutycycle throughout the load range, or is there a programming stop for high loads (EGR is automatically disabled by lack of vacuum, but I never checked to see if the EGR is still controlled on electrically)? Just a thought for incorporating alcohol injection delivery via the factory PCM. If it turns it off at higher loads and cannot be maintained or increased, then its seems useless for that application.
