Slyclone
Well-known member
Just wondering if anyone here has ever had the dipstick tube snap off. Mine was weak, on its last leg on this typhoon and it snapped off clean on the bottom.
Noticed it was missing...I tried to put a dipstick in and it bad only going so far.. Tube looked bent or kinked I than saw it was welded. I went to remove dipstick tube and the repair area close to the bottom snapped. Wonderful.
I thought I was going to be able to pull it out but there's at least 5 inches still inside. I think when the tube was welded by previous owner or some one it expanded the metal and the tube was not able to fully go in.. Or pull out.
So my question now is.. Is the only way to remove it from the bottom? Which requires a mega-ton of work...? I think I remember lifting the engine on my syclone ( with trans out) and than tearing the timing cover/oil pan gasket. Just when I thought things were going OK.. This turns in to a huge operation. I removed the starter and thought it would buyvme a little space to work.. Not enough to get a good bite on it. Anyone have this happen??:roll:
