Hey guys I'm back. I went to the track this weekend and ran like crap. Besides sleeping off the line I was only able to get 12 lbs at wot. This is providing the gauge is right. I reinstalled the gauge supply line into the brake booster feed on the intake plenum. Good?? I also replaced the intercooler pump and ran the rubber lines. New ATR wires and NGK plugs. Also a new conrad cap & rotor. Now is it possible for the VDO boost gauge to have gone bad or will they just stop working. The reason I ask is because the factory gauge is pegging and the VDO is only at 10-12. Before I moved the feed line they were only about 3-4 lbs different. I'm also using the ATR boost control valve. My speeds were only 86-87 mph and my times were 15.3 to 15.6. Any ideas? Also if I were to get an Ultimate chip are there any other things I should consider. I will be getting an aux. cooler to run in series with the factory exchanger. Thanx for the time and any suggestions.
TY1173 :bad-word: :banghead: ::thumbsup::
