Flip#32
accidently I started my ty right after checking for any codes, It cranked right up, but sounded funky, and the check engine was going nuts. I knew something was wrong & shut it off. I then noticed the jumper wire was still in the obd1. Damn I am so close to finally fixing all of this ones issues, now this.. I pulled the jumper wire out, but it hasn't hit a lick sense. All fuses checked good, its getting fuel & I wanna say it isn't getting any fire to the plugs. I pulled wires off, cap off, rotor button & ignition module out. Yea, im a real mechanics nightmare. I thought I had replacement parts in stock, but only had a cap. Im currently reassembling the distributor (with its old cap) so I can double check that the plugs are truly not firing. If it has indeed lost fire, could I be going in the right direction thinking the ignition module has died? Maybe fried the computer itself?
