Comp 422 Cam FS-200 shipped-SOLD
nallj92
Selling a comp cams 422
http://store.summitracing.com/partdetail.asp?part=CCA-09-422-8&autoview=sku
Part Number:CCA-09-422-8
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:2,000-5,500
Intake Duration at 050 inch Lift:215
Exhaust Duration at 050 inch Lift:220
Duration at 050 inch Lift:215 int./220 exh.
Advertised Intake Duration:270
Advertised Exhaust Duration:276
Advertised Duration:270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.500 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.510 in.
Valve Lift with Factory Rocker Arm Ratio:0.500 int./0.510 exh. lift
Lobe Separation (degrees):114
Has 1500 miles on it.
265 new from summit.
200 shipped
