AutoVation
Re: Changing out distributor, is this the right wrench?
Ok, i've got the distributor bolt out using this combination:
- 1/4" drive 9/16" socket
- 1/4" U-joint
- 6" 1/4" extension
- 1/4" to 3/8" adapter
- 6" 3/8" extension
- 3/8" driver
I put the socket and u-joint on the bolt and then connected the extension to the u-joint "through" the manifold area. :rotf: I will post a pick shortly since there is no way to describe it.
Next step, I've lubed up the MSD, put on the new shaft gasket and dropped the MSD into the hole. I can get it all the down to about 1/2" above where it needs to seat and I can't seem to get it any further. It bottoms out with a metal on metal sound. I pulled the MSD back out to make sure it wasn't longer than the OEM and it is not. Do I need to rotate the gear somehow? I'm not really sure how to do that at this point, I'm doing more searching.
After some searching, I need to turn the engine over so the oil pump (and gear) will move and the distributor will just "drop in". Do I just turn the key in the ignition and the distributor will drop in or do I need to do this manually somehow?
- 1/4" U-joint
- 6" 1/4" extension
- 6" 3/8" extension
- 3/8" driver
