Sy Guy 0024
Noticed my speedo/odometer weren’t working, and found a broken pink wire at the DRAC. You know, the white box that piggy-backs on the ECM? Problem is, the wire broke at the metal clip that is inside the plastic connector. I know GM (and I’ve heard Snap-on has them) makes a tool to remove the metal clips, but I was hoping to find something more quickly/cheaper. I’ve got some thick paper clips that I think will depress the locking “tang” on the metal clip, but I’m not sure how I’ll pull the clip out. Can’t pull the clip out by the wire since it’s broke so….
Has anyone done this before or got some suggestions on what to use? Found an old post from 2001 where some guy soldered his wire back to the clip w/o removing the clip from the plastic connector, but I’m not sure I’ve got those skills. Any thoughts?
Corbin
Corbin
