In an attempt to replace the fluid and filter in my transmission today, I discovered that the pan bolts are going to be a problem. I started to loosen the first bolt, which felt snug but not really tight, then the head of the bolt broke off even with the transmission casing. Assuming that the bolt just broke, I attempted to remove two more bolts with the same result.
Anyone have a suggestion before I try any more bolts just to have them break? This is the first time I have tried to remove the tranny pan because the fluid/filter was replaced just before I purchased it 2 years ago. Perhaps someone used an impact on these last time?
