Fist off...Great site. I've been looking here off and on for a while looking for info on theise rare super SUVs. I'm fairly new to the 90* V6 but long time Ford turbo 2.3, and 60* GM v6 fan. I've also played with a turbo 4 '88 mazda MX-6 GT.
Well im doing a engine swap on my 87 ford t-bird turbo coupe. The 2.3 had the HP and tq..but not the ability to hold together on the long run (121hp per liter on a 3500lb car). The engine is a rebuilt 229ci I had collecting dust, then I plan on max porting, caming and turbocharging it. Trans is beeing swaped for a v8 thm350. Maybe now I can pull the front wheels off the ground
. Well I'ved searching but nothing comes up. Heres my questions:
Is the 229s Crank better (jurnal strenth) since its semi odd fire over the even fire 4.3? If not.. At what tq should I consider swaping to a 4.3 engine. Mind you..I will see 6K rpm at the most.
Are the cast pistons OK at just a little under 350hp/ 400tq for now? Will 305 forged slugs fit?
Will the spark timming stradagy/fueling from the $58 code work correctly using the semi odd fire dizzy with a ecm controled HEI modual? If not..is there a patch for the code (cylinder select/refrence angle)?
Edit: Sorry I forgot to ask..but are sy/ty exhaust valves inconel? Will the stock valves work?
