Billet dual fuel pump hat for oem gas tank
Syclone22
Looking for an vendor that makes a billet dual fuel pump
hat with AN fittings to fit the oem tank any input would be great ..
Z SKI
Re: Billet dual fuel pump hat for oem gas tank
You can get the parts to do a dual-fp from Racetronix but I think you may have to build your own lines... not hard at all and you can make sure that the lines you are using are rated for the type of fuel you are planning to use..
Syclone22
Thanks Paul currently using a double pumper from RPM but would like to convert to a billet
hat just like the Aeromotive units these use AN fitting with no O ring seals .
