Belltech Springs and Swaybar
kue
I bought a set of Belltech sway bars as part of the GP several months ago for my Ty. At the time it sounded like the rear sway bar would work with the belltech drop leafs that are already on the truck. Well I tried to put the bar in and it rubs the leaf springs when the truck is on the ground again. No amount of adjusting that I did resolved the problem.
Has anyone else put the belltech rear sway bar on a dropped ty? Trying to get an idea of what others have done since I couldn't find to much by searching.
I have my original springs and a set of blocks that I could put back in. I dont like using the blocks because I have heard of them breaking. What are your thoughts??
hideakimura
NipponSyTy
Same here, I also would like to know the good solution but I guess there is no...
Mine didn't rub when the truck is on the ground (but still really close to leaf like 1 inch)
Then I ordered Bell's shim'ed 1'' block to make more space on the top of the leaf.
I have read some of them put blocks on the leaf and breaking of FG leaf but haven't heard of breaking of Bell's leaf and Bell's block setups.
And I did reroute the side brake line to avoid to apply any tension.
kue
Well I still have my original springs that had blocks on them when I purchased the truck. I just don't trust the blocks because I have heard bad things about them. Is there a "better" drop block brand that someone can suggest, I am all ears.
